Bending, Deflection and Stress Equations Calculator for Cantilevered Beam with Load at Location Between Support and Load
Structural Beam Deflection, Stress, Bending Equations and calculator for a Cantilevered Beam with Load at Location Between Support and Load.
Open
Stress and Bending Cantilevered Beam Load at Location Between Support Calculator
Beam Stress at specific point
Beam Stress at the support (must be constant cross section)
Beam Deflection between support and load
Beam Deflection beyond load
Beam Deflection at load
Deflection at load
Maximum Beam deflection at end
Maximum deflection at end
E =  Modulus of Elasticity psi
(N/mm2)
W =  Load lbs (N)
s =  Beam Stress at the cross-section being evaluated lbs/in2 (N/mm2)
l Some distance as indicated inches (mm)
v = Some distance as indicated inches (mm)
b = Some distance as indicated inches (mm)
Z =
z =
  • Please note letter "l" (lower case "L") is different than "I" (Moment of Inertia).
  • Beam Deflections apply only to constant cross sections along entire length.
  • Machinery's Handbook, 21st Edition, Page 408 or,
  • Machinery's Handbook, 23st Edition, Page 264 or,
  • Machinery's Handbook, 27st Edition, Page 265
